Getting error 26251 from Application Builder ?
I'm getting the following when running Application Builder to create an installer with a minimal LabView 7.0 app (while loop + stop button !) - "Error 26251 occurred at Build Application.vi >> Dist Call Create Installer.vi >> Win Install Create.vi >> MSI DK Close.vi. The error code is undefined ... etc". I've run an installation repair on LabView, uninstalled and reinstalled AppBuilder 7.0. The error only occurs if the Labview Run-time Engine box is ticked under the Installer Settings - Advanced. LV 7.0 run-time is installed.
Any ideas ? Thanks.
(2,948 Views)
Neil,
Is the disk where you are building your installer to (the drive for "Installer directory") nearly full? If so maybe there is enough space to build an installer, but but not enough to build one that includes the Run-Time Engine. The Application Builder initially creates some of the installer files in a temporary location and then copies them to the final location at the end.
Kennon
(2,948 Views)
Thanks Kennon - Dead right. I used a network drive and over time it had filled up. A simple "Disk Full" message might have been handy ! 🐵 Best Regards Neil.
(2,948 Views)
