Getting error in call library node when establishing communication with MAX1452 on serial port using dll
Ideally this conversion should be done by the function built into the DLL and you should directly receive the port address as a 16 bit signed integer. But again, since I am not aware of the internal working of the functions used in the DLL file, I can not be sure.
Currently i do not have LV 7.1 installed. I used LV 2010 and got the following error while loading the DLL:
If you are certain this is a LabVIEW issue and not dll's you should contact NI support.
I will try to load this on an XP system with LV7.1 and let you know the observations.
Message 11 of 11
(367 Views)
