Getting graph scales and grids to only show integers
How do I get a mixed signal graph as shown in the attachment to only show the whole integers on the y axis and reduce the grid to doing the same?
(2,656 Views)
Accepted by topic author id
programatically, you have a property node for the graph scale that should do the job :"increment"
=> property node, Y scale, range, increment.
The grid will follow.
The minimum increment depend on the graph vertical size (and marker font size I guess, wich also has its property node)
example attached, hope it helps.
antoine
(2,644 Views)
