Getting started window keeps appearing after testing with Teststand
Hello everyone,
I have a question. We have a test station for production, and every time they run a test with TestStand, at the beginning and end of the test, the GSW appears. This is very annoying and I haven't found any solution for it. Does anyone have an idea what might help?
I already tried in LabVIEW:
Tools>Options>Environment> "Skip Getting Started Window", this just opens a blank vi during testing
Modify the labview.ini file, with the command: showNoNavDialog=True, also opens blank vi
Using:
Labview 15
Teststand 16
Windows 10
Greetings,
Jonathan
Failing organizations are usually over-managed and under-led.
(3,490 Views)
Have you tried to use the LabVIEW Runtime Engine instead of the LabVIEW Development Environment?
Marc Dubois
(3,454 Views)
Yes, but we would need to switch every time we want to test or develop. We dont want to use the runTime Engine untill every testprogram works. Untill then we need to surpress the Getting Started window somehow.
(3,450 Views)
You probably also saw this post (changing TestStand Window Activation on the run options tab of the step properties) but just in case...
Marc Dubois
(3,444 Views)
Saw it and tried it. But with the second solution nothing happened. Instead of keeping Teststand in the front, the LabVIEW Getting Started Window was kept in the foreground.
(3,440 Views)
