Getting tag of selected item in a treecontrol
I want to get the currently selected (highlighted) item (actually it's tag) in a tree control at run time.  How?
(2,828 Views)
Hi, Pake.
I found a KnowledgeBase that includes an example of some code that does exactly that. Good luck!
Sarah K.
Search PME
(2,816 Views)
Hmm, to get the selected tag, all you need to do is read the value from the control terminal, since the currently selected value of a tree control *is* its tag.  You could alternatively read from a local variable.  If you needed to get the value in a subVI, you could wire a Control Reference into the subVI and read the Value property.
-D
(2,812 Views)
