Getting the Maximum and Standard Deviation
Hallo,
i try to get from a light spectrum the maximum and Standard deviation. I Have a x and y Array with Wavelength a the measured intensity.
At the moment i get the Wavelength where the max of Intensity is, by mulitply the to arrays, searching for the max with the array min max and getting with the index the Wavelength.
When i search for the standard deviation of the intensity i dont know how to get to the Wavelength intervall.
Does anyone know how to handle my Problem
Greets
Felix
(2,629 Views)
Hi (Hallo!) Felix,
it's nice you included some default values in your VI, so we can test with real data…
I simplified the VI as such:
What's wrong with the StDev you calculate so far?
Why do you need to multiply wavelength with amplitude?
Which "Wavelength interval" are you interested in?
(2,608 Views)
Oh, your right the multply of amplitude and wavelenght was a mistake.
I try to get the widths of the sprectrum around the standard deviation of the Amplitude.
(2,603 Views)
Hi Felix,
You know the peak amplitude and wavelength.
And you calculate some StDev value of the amplitudes: what exactly do you want to achieve with this value?
Can you attach an image to show/explain your requirement?
(2,583 Views)
I wanna build a EQE Test, for doing this i neet to get my Sprectrum more narrow. To fullfill the Formula to get the sprectrum more narrow i need the Width of the spectrum and for this i need the Standard devation.
(2,572 Views)
Hi Felix,
this is more math than I want to handle right now…
The width of the spectrum is given by your data: there is a minimum and maximum wavelength…
When I asked for explanation I was expecting an image of the graph showing your measured spectrum and maybe two cursors to show the range of the data you want to determine by using the StDev…
(2,568 Views)
