Getting the area and circumference of XY graph
Hello
Please I need help as soon as possible with This Labview Code.
This code include drawing manually a circle on the XY graph to calculate the area and the circumference of it !
But  I need an improve of this code to make it more beneficial, I want to find a way so the circle will be drawn automatically when I run the program and choose the the txt file for X & Y in a way to cover like at least 95% of the graph!!
Thank YOU
Message 1 of 11
(4,459 Views)
here are the two txt files X and Y
Message 2 of 11
(4,456 Views)
Hi!
The Easiest way of drawing circles in XY graphs is by generating sine and cosine values. Please check out this simple example:
You can modify the Number of Samples input of the sine generation to make te resolution finer or coarser.
Hope this helps.
Regards:
Andrew Valko
NI Hungary
Andrew Valko
National Instruments Hungary
Message 3 of 11
(4,401 Views)
could you please send me it in the Labview?
Message 4 of 11
(4,399 Views)
Sure, here's the VI, though you can also drag and drop the .png into the block diagram.
BR:
Andrew
Andrew Valko
Message 5 of 11
(4,394 Views)
I have Labview version 2009 ! I could not open this
Btw Thank You so much
Message 6 of 11
(4,392 Views)
Sorry But I need it with labview 2009 version
Message 7 of 11
(4,386 Views)
Sure, here you go.
Andrew Valko
Message 8 of 11
(4,384 Views)
where can I put inside the code?!
Message 9 of 11
(4,378 Views)
hello
Please This didnt work out... could you please help me to find the area and circumference of the XY graph in another way ( without using the circle)??
Message 10 of 11
(4,351 Views)
