Getting the label of structure
Is there any node in LabVIEW which gives the output as a name of the structure(For, while,case, timed loop). I tried with property node but that failed. Is there any other way to solve this problem??
(1,611 Views)
Hello!
Are the Generic.Class Name and Node.Label.Text properties the ones You are looking for?
https://zone.ni.com/reference/en-XX/help/371361R-01/lvprop/gen_class_name/
https://zone.ni.com/reference/en-XX/help/371361R-01/lvscript/node_label/ 
(1,578 Views)
One thing to be careful of is that the Flat Sequence Structure only inherits from GObject so the above code would throw an error when you tried to cast that reference to a node.
(1,566 Views)
Thanks, It works
(1,455 Views)
(1,432 Views)
