Getting the last data value of each segment in lmv file
Hello everyone,
I am working on a program in which I use Write to Measurement file VI to save segments of a signal. I have selected the option of having one header per segment and the option of having one time column. So, in each header I have the info of the Start time, andthe first column of each header displays the relative time passed since the start time. What I need to obtain somehow is the relative time of the last data of each segment. This would be the delta time passed since the start of the measurement. Does anybody know how to do this? Is it possible at all?
Thank you very much in advance.
(2,278 Views)
Could you please attach an example generated measurement file, so I can see how your columns and rows are set up?
Cory K
(2,268 Views)
I think we'd need a little more information in order to help you on this.  Do you have a time corresponding to each data point?  It would be helpful to learn a little bit more about the properties of the signal you are trying to save.
Jon S
(2,232 Views)
