Getting values from table
  I have a table.  Here are the things that  I want to do.
1. Whenever somone click on a row the entire row should highlight
2. Get the values from that colomn.
Can someone help?
thanks
--trupti
(3,129 Views)
Hi
I made you a VI that gets you the row were the cursor exists. This might help.
Remember that Tables work exactly like 2D array.
Good luck
Tareq
(3,118 Views)
The multicolumn listbox has the property that clicking in a given row will highlight the row.  You can extract a given column using a property node to access the item names property (a 2D array of strings, just like a table) - I use the property to programmatically write the listbox elements in the attached example.  The example doesn't do anything interesting, it simply shows how to populate the listbox programmatically, and illustrates the row-selection behavior you seem to desire.
I hope this helps!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,107 Views)
