GigE Vision - 12bit packed image
I have a AVT Prosilica GX3300 camera that I am trying to acquire 12-bit PACKED imagery.  I am able to send the commands for the camera to operate in that mode no problem, but when I go to write the image into a binary data file, it saves it as 16-bit.  My guess is that LabVIEW is upacking the data to display it to the screen; however, I really want to have it packed when writing to disk to minimzie storage requirements.  Any clue?
(3,843 Views)
The Image datatype can only store images in multiples of 8bits. This is why a 12bit image will be represented with an I16 image in LabVIEW.
This KB gives some details.
Christian
(3,810 Views)
You can convert this to an array and repack it and write thr binary packed data if you need this.
Imaq to array, convert this to a flat 1d array of U8 and unpack by writing, just a combo of putting the nibbles back together and removing the extra 4bits out of each 16bits.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,795 Views)
If you have the 16-bit data, I wrote this one time to accomplish the same thing.  I basically switched between writing a byte (8-bit) and a word (16-bit) while passing the extra nibble around.
GCentral
(3,789 Views)
