GigE camera Lost Packets - Jumbo Frame
Have you seen this KB?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Lj9SAE&l=en-US
I've had to configure the Ethernet adapter to allow jumbo frames in the past if it's an Ethernet connection
Message 11 of 12
(651 Views)
Hello.
I've such issues for years and didn't find suitable solution yet. My imperfect fix for this is to decrease the bandwith in NIMax to a 'suitable' level that has to be find case to case:
I've also noticed that toggling the 'resends enable' option on and off helps to get back the stream
It seems that there is something wrong in the network adapter options but I do not know wich one. Other OEM soft ( the one from the camera manufacturer and from their competitor) do lose packet but the resend options do work as expected ...
I also have the feeling that if you could match exactly the jumbo frame size and the packet size, it might go better. Unfortunuatly, NIMax is not happy in my case with packet size of 9014
Good luck to anyone
Message 12 of 12
(193 Views)
