GigE camera with cRIO-9068
Hi everyone!
I have short question regarding the possibilities of my cRIO-9068. I want to use my GigE Mako G camera with it, plugging it into secondary ethernet input. But I can't see it in MAX, although I tried some steps with IP settings..
I have read somewhere on this forum, that there may be a problem with cRIO's using GigE cameras. Is it really no possibility at all to use this camera, or should I just change some settings of it? Maybe change the settings from GigE into normal Ethernet?
I would be grateful for any help!
Jola
(4,280 Views)
Did you install IMAQdx from the Add/Remove Software dialog?
(4,249 Views)
Follow the steps in Troubleshooting GigE Vision Cameras
uday
(4,238 Views)
natasftw,
yes I installed IMAQdx on my host, as well as on the cRIO-9068. But I can see that there is only IMAQdx for IP cameras, and not for GigE camera:
problem.pngAs far as I know, it is not the same. Isn't that a problem? Why there is no package for GigE?
greetings!
(4,231 Views)
udka,
this troubleshooting tutorial is for cases, when you switch GigE camera to the host computer and not directly to the cRIO-9068. I had no problems with computer, camera works fine in MAX and in LabVIEW, but it seems that it is much harder when plugging camera to the secondary ethernet port on cRIO-9068.
Have you got any tutorial for my case?
(4,229 Views)
9068 does not support GigE Vision, hence you might not be able to use it.
From: https://forums.ni.com/t5/Machine-Vision/GigE-vision-on-NI-cRIO-9068/m-p/2922286/highlight/true#M4293...
uday
(4,224 Views)
