Give commands to two keithley2400 at the same time
You give the same command whether you use a VISA Write, the single GPIB Write, or the multi-address Write. The trigger is generated after you configure each instrument. You either generate the software trigger or the hardware trigger.
Message 11 of 11
(716 Views)
