Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Giving a specific path to the reading from excel application
tchaou
Member
03-01-2007
02:43 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hello, i want to know there is a way of giving a specific path to an application (reading from excel sheet) without all the time getting to enter the path? if someone could help. i'm using labview 8.0
Tchaou
0
Kudos
Message
1
of 3
(2,774 Views)
Reply
Re: Giving a specific path to the reading from excel application
Joe_H
Active Participant
03-01-2007
05:52 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you could just use a path constant. Drop a path constant on the BD and right click on it and select browse and then find the file you want.
Joe.
"NOTHING IS EVER EASY"
2
Kudos
Message
2
of 3
(2,767 Views)
Reply
Re : Re: Giving a specific path to the reading from excel application
tchaou
Member
Author
03-12-2007
04:01 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
hi
Jhoskins,
thank you for your reply it works.
Regards
0
Kudos
Message
3
of 3
(2,744 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
