Global Variable
Dear All
I have a VI Containing a sub VI. When I press a botton, the Sub VI opens and if I press another botton in the Sub VI's Front Panel, a boolean global variable turns ON but when I exit the Sub VI, the global variable returns OFF. How can I have a Global Variable that when I exit the Sub VI it still remains ON.
Regards
V.S
(4,494 Views)
Hi VS,
attach your VIs…
In the meanwhile you should not write a FALSE to your global variable when exiting the subVI…
(4,478 Views)
Dear GerdW
Please check the attachment.
(4,465 Views)
Hi VS,
what happens when you call your subVI with "Enable2"=FALSE?
Have you ever debugged your VIs?
Have you even considered your subVI is also called with a FALSE input?
(4,456 Views)
Dear GerdW
Thanks for your valueable questions. I found my fault. I Conidered that when I switch Enable2 to false the Sub VI does not execute which is not correct.
Best Regards
V.S
(4,443 Views)
