Global Variables: Controls or Indicators?
When you create a new Global Variable Front Panel, you can drop both controls and indicators. You can change controls to indicators and vice-versa. Regardless of directionality of the FP object, the Global Variable acts the same from callers - both still have Read/Write capabilities.
So, is there any distinction between a Control and an Indicator on a Global Variable Front Panel?
(6,052 Views)
One distinction that comes to mind is that while a VI using a global is running I can open the global variable and muck with the values of the controls and not of the indicators.
(6,039 Views)
That's the only distinction I can think of as well.  For run-time debugging, you would want controls.  Shouldn't matter for any other purpose.  Personally, I always use controls, since the vast majority of globals I write are storing default values that I'm simply reading in various places in my code.  And semantically, it makes more sense to me that I'm reading from controls.
(6,026 Views)
Good answers, those were my thoughts as well. So, why are indicators allowed on Global FP's?
(6,016 Views)
To mess with people's minds.  Smiley Very Happy
- tbob
Inventor of the WORM Global
(6,007 Views)
Indicators are there to be read-only whose value can only be changed at edit-time and thus provide a relatively efficient way to define constants.
Oops, I was dreaming there and just woke up.  I guess sometimes you need to keep those wacky users from messing with your data while your VI is running.
(6,003 Views)
Anyway, my thoughts about the indicator/control conundrum of Global FP's are half-formed at best, and as Darin has introduced, I'm thinking about a global CONST.
Could there be two types of Global Front Panels, one with only controls allowed (the current implementation of globals where all elements are read/write) and one with only indicators allowed (the CONST panel, all elements have read-only access)?
Message Edited by JackDunaway on 06-04-2010 12:50 PM
(5,984 Views)
