Global "pseudo-WORM" or preview Notifier?
Access to a functional global is your biggest source of jitter?   But your "heavy load" access rates are in the order of ~5 client accesses per 50 msec?   That doesn't actually sound very demanding.   Is the code structured to cause client accesses to be syncronized rather than asynchronous?  Are you sure the jitter is due to access and blocking effects rather than variable time spent inside the func global (or even elsewhere)?
Well, regardless, you may as well make the fairly simple switch to a standard global variable so you can compare.
-Kevin P
Message 11 of 12
(404 Views)
Q,
How much data is involved? If it is small, spawn a copy for each client process.  Then the only delay you have is at launch time and you will never have blocking.
Lynn
Message 12 of 12
(388 Views)
