Global variable not being updated!
I have a vi and in the front panel I have knob called Frequency (Hz) which can have a value of 0 to 3 inclusive. It updates a global variable Fselect I then read this global variable and the value that I read is always 0 even when I have turned the frequency knob to give outa different value.
Whats going on? I can't seem to debug this and I'm sure it was working earlier.
Vi is attached
Best regards
Javed
(3,040 Views)
I've tried in my pc and the it seems to be working. I putted a probe on the global variable on the lower cycle and when I change the freq, it updates also the value on the prob.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,032 Views)
When the inner-most while loop is running, you will not see an update on the global variable in the lower loop.  It will only update after the inner-most while loop is stopped.
Tom
(3,018 Views)
