Global variable value update to indicator on run time
everything recursive can be done iteratively
that's what loops are for
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 41 of 58
(1,555 Views)
Yes i mean re-entant subvi that i set in properties of subvi
Message 42 of 58
(1,546 Views)
If i press boolean button it shout keep on update string indicator of main (because of subvi is recursive subvi).
subvi calls recursively whenver the second if condition becomes true or else it will not update string indicator.
For my testing if i make second if equlal to  true then string indicator should update. (even if it updating with same string also ok ).
Regards
Punith
Message 43 of 58
(1,537 Views)
Hi Friends,
Do i need to provide any more information?.
Kindly suggest me.
Regards
Punith
Message 44 of 58
(1,508 Views)
I'm not clear if you are clear on the terminology.
recursion:  a subVI is able to call itself
reentrant:  a subVI can be called multiple times from multiple places, they are separate instances of memory space and are able to run simultaneously.
non-reentrant:  a subVI has only 1 instance that can be executed at a time.  If it is called from somwhere else, it must wait until the first instance is done executing before the second one begins.
Actually, recursion never existed in LabVIEW until fairly recently.  It is a very uncommon use case, and I doubt that you actually need recursion.
Message 45 of 58
(1,496 Views)
Oh man, how I love, when I find something that can be done with real recursion... It is as you say very uncommon, though.
Remember Cunningham's Law
Message 46 of 58
(1,483 Views)
my subvi nopt calling only once so it is recursive(calling itself). Anyone did implemation in my code.
Regards
Punith
Message 47 of 58
(1,479 Views)
You say in your VI's that the LAB_VB_AVTV2_data_calculation.vi is the recursive VI that is calling itself.
Have you attached that anywhere?  I don't see it in any of your messages.  Until we see that subVI, we can't see how you have it calling itself.
Message 48 of 58
(1,472 Views)
HI friends,
The subvi_test1.vi itslef LAB_VB_AVTV2_data_calculation.vi .
Did any one solve my problem?.
Regards
Punith
Message 49 of 58
(1,443 Views)
Only question is,
If SUBVi is recursive and its keep on giving output. How to update this output in main indicator.
If any one did changes in my main_test1.vi and subvi_test1.vi, kinldy let me know.
Regards
Punith
Regards
Punith
Message 50 of 58
(1,440 Views)
