Global variables scan
I need to load and store global variables into a file.
I would make an automated vi that opens the (ini) file and for each global variable tries to read (or store) its value in the file.
To do that I would need a property node linked to global variables (or a method to get an array of "Control Refnum" to be scanned).
Dario
(3,141 Views)
I tried to delete this thread but I don't know how to do it ...
Anyway, I already found a solution ....
(3,109 Views)
You can't delete threads. As far as I know, deletion is possible only by NI.
What solution did you find?
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,098 Views)
See the example below.
Regards
(3,095 Views)
