Global variables
Hello Sir,
I was working on Global variables in the multiple VI's. When run the VI files then the Global variables will work fine.
But when I create a project for an executable file, If i execute that exe file then Global variables will not work.
I want the global variables to work in executable file.
Please help me for this issue.
Message 1 of 8
(2,589 Views)
Were the global VI's included in the executable?
I'd think they'd be included by default, but you might need to specifically include them under the build is some unusual circumstances.
When you say "will not work", what precisely do you mean?  Are you getting any error messages?
Message 2 of 8
(2,565 Views)
Another reason your global variable are not working is because of race conditions.
Former Certified LabVIEW Developer (CLD)
Message 3 of 8
(2,562 Views)
Without knowing what "will not work" means specifically or how your program is architected this was my thoughts too. If you could show us your code we might be able to help spot potential race conditions.
Message 4 of 8
(2,551 Views)
Are you creating one executable for everything or one executable per VI? AFAIK you can't use global variables across multiple executables, but I've never tried. I think you'd need a Shared Variable for that.
Message 5 of 8
(2,542 Views)
I'll throw out another possibility.  Maybe the desired values need to be set to default before building.  Better would be to set the values at startup from a configuration file.
Message 6 of 8
(2,505 Views)
Or a hybrid that would read the values into the global from a config file... or is that what you meant in the first place?
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(2,452 Views)
Yes, that is exactly what I meant in the second half of my post.
Message 8 of 8
(2,445 Views)
