Globals in VIs converted from LV6.1 to LV8.0
All,
I
(2,745 Views)
Looks like you may have been stung by the tab behavior.  🙂 I have posted too fast way too many times not to sympathize.
I am posting so hopefully you get the notice and can ask us your question.
(2,740 Views)
Hopefully this will work.
All,
I am having a problem with Globals variables.
I have converted our code from LV 6.1 to LV 8.0. In one instance a VI writes some globals which are available for use in other independent VIs. After converting these global values are not reliably available when running the separate VIs. I see LV8.0 uses shared variables and have found info talking about usage and differences but nothing stating traditional globals must be converted to shared variables in LV 8.0.
Is conversion to shared variables the answer or am I missing something else?
(2,723 Views)
This post is a duplicate.  Please follow the discussion here.
Thank you.
Travis M
LabVIEW R&D
(2,705 Views)
