04-11-2006 08:53 AM
04-11-2006 09:03 AM
04-11-2006 10:56 AM
Hopefully this will work.
All,
I am having a problem with Globals variables.
I have converted our code from LV 6.1 to LV 8.0. In one instance a VI writes some globals which are available for use in other independent VIs. After converting these global values are not reliably available when running the separate VIs. I see LV8.0 uses shared variables and have found info talking about usage and differences but nothing stating traditional globals must be converted to shared variables in LV 8.0.
Is conversion to shared variables the answer or am I missing something else?
04-12-2006 11:01 AM
