GoF Adapter design pattern
Hi, all,
Is it possible to implement anything like the Adapter design pattern in LabVIEW? I'm thinking of a situation where we are running a system test application in which the devices in the system may be either simulated or real. The Adapter pattern would allow such decisions to be deferred until runtime by plugging hardware implementations into VIs representing the abstract devices.
- Steve.
(3,578 Views)
Sure, I've done that a few times.
I have used VI Server for this. If you use Run VI function, it's almost the
same as calling a normal VI. But all connector panes of the VI's you want to
call have to be the same. If you want to determine the connector pane
controls at run time you can do so with Set Control methods.
LabGOOP can also do this, although I'm not sure if you can load objects
during run time. It's to heavy for me.
Wiebe.
(3,554 Views)
Thanks. I modified a copy of the LVOOP stopwatch demo to insert different "movements." -S.
(3,489 Views)
Can you post a link to the stopwatch demo that you mentioned? I haven't heard of it before.
(3,420 Views)
(3,418 Views)
(3,416 Views)
