GoPro in LV
Hi guys!
So, has anyone tried using a GoPro in LV? Did you need any extra drivers or workaround to get it to work, or is it just to connect and grab through IMAQdx?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,451 Views)
Accepted by topic author Yamaeda
Hi Yamaeda,
Have you had any luck communicating to yor GoPro yet?
I found a couple of other people trying the same sort of thing, looks like you might need to connect via wifi or bluetooth.
https://forums.ni.com/t5/facebookforums/facebooksingletopicpage/facebook-app/417075545007603/message...
https://forums.ni.com/t5/Machine-Vision/LabVIEW-control-of-a-GoPro-camera/td-p/3175469
Hope this helps
Pete
Certified LabVIEW Architect
(5,353 Views)
Accessing it via http should be simple enough, though quite a change in my current test program that uses IMAQdx. I'll try to get a hold of a camera and do some real tests.
/Y
Qestit Systems
(5,319 Views)
