Going crazy over staled f***** array values
Need some seriouse help now.
My goal is to build an array everytime a true button is pressed.
1. Create an array based on values programitlitly beeing passed into the array
2. This should happen everytime  when a boolean value goes true.
3.The array building function should wait 6 s before storing it into the array when the value goes true
My problem is that when i press True, and i start changing the  start value(lets say 0) to desired value i want it to be(lets say 5)  before 6 second passes, the value passed to the array after 6 seconds is the start value 0 not the dessired value 5. This value appeares the next time i push the true button.
It drives me crazy
And the desired value needs to come inside  from an sequense structure because of the structure of the main VI(this is just a snippet of that cose)
HELP plz!!!!!
(4,009 Views)
Accepted by topic author torkil
Probably this should solve your problem.
(4,002 Views)
Hmm, deja vu
Oh for crying out loud, keep it all in the same place
_____________________________
- Cheers, Ed
(3,996 Views)
That would actually be this as the original post: http://forums.ni.com/t5/LabVIEW/Build-Array/td-p/1998291
torkil: we don't like people who create duplicate posts. It's the fastest way of getting ignored.
(3,970 Views)
Sorry
I have a deadline in 2 days to get project together,kinda stressed.
Have used 40 hours on this issue so i snapped a little bit ,sorry
(3,952 Views)
