Good practice to reduce I/O Node's FXP bit-width for FPGA Optimization?
I'm reading from some cRIO cards that output <+/-,24,10> FXP's which is *much* wider than I need it to be.  I'm reading in voltages that are always positive and less than 100V and I have a 1mV accuracy requirement.
Is it good practice to immediately add a "To Fixed-Point" primitive after the I/O node to reduce a <+/-,24,10> to a <+,17,7> (in this case) to save 7 bits per I/O channel and possibly more if I do any sort of math upon them?
(2,412 Views)
Accepted by topic author SeanDonner
Hi Sean,
when you are sure you don't need those extra bits then you can convert to a different FXP representation…
(2,405 Views)
