Got a fairly general spreadsheet parser?
Anyone have a fairly general spreadsheet parser?
My application has several classes of spreadsheet, each of which needs to be parsed into different somewhat complicated structures. This kind of think seems likely to have been done a zillion times and have no desire to reinvent the ole rounder.
Thanks for any help you can provide.
Fred
(2,590 Views)
I suspect that lots of us have written parsers, but a general purpose one gets very messy very fast. Look at the Scan String for Tokens function in the string palette >> Additional String Functions. It takes a bit of work to see the power of it for a parser, but it is worth the effort if you have to write your own. I used it to write an assembler for an obsolete microprocessor that I needed to continue supporting. The result was much more versatile than doing everything with Match Pattern.
Lynn
(2,558 Views)
