Got error -2147220597 when downloading FPGA bit file to NI 9068
The detail message is
Operation failed!
Error -2147220597 occurred at an unidentified location
Possible reason(s):
NI System Configuration: (Hex 0x8004038B) The specified firmware was not successfully installed. See the output parameters for more information.
The code worked untill I recompiled the bit file and downloaded it.
Didn't find any related posts. Anyone has had similar issue and knows the cure.
Thank you very much for your help.
(2,942 Views)
Hi Ya-hoo
I was able to find one instance of this error. It looked like latest NI-RIO driver was able to fix this issue.
What version of LabVIEW and NI-RIO driver are you currently using?
I would recommend upgrading to the latest NI-RIO driver that is compatible with your LabVIEW version. Refer to this table:
https://www.ni.com/en/support/documentation/compatibility/17/ni-rio-and-labview-version-compatibilit...
NI-RIO drivers can be found on www.ni.com/downloads/
(2,889 Views)
Found the issue was that the NI RIO drivers on my PC, where the FPGA code was compiled, and on hardware are not same.
Error message is not quite relavant.
Thank you for the reply.
(2,878 Views)
