Gps api V2
I have a Gps program which displays  the location using google maps. But it doesn't work sinc eit uses static map API V1. I tried implementing the static map 2 api from: https://developers.google.com/maps/documentation/static-maps/upgrade. But didn't succees
d. Can someone provide me some help. I am stuck since a week
(3,363 Views)
You posted this with LabVIEW NXG tag, but uploaded it with a standard LabVIEW VI attached - so I'll assume you meant that.
Anyway, take a look here.  There is an API for GMaps available.
(3,313 Views)
Here is attached GMAP.NET v1.7.0.0.zip.
(2,738 Views)
