10-02-2007 09:30 PM
The Times is probably not the best choice. I'd find out what the local Beaverton paper is. Maybe a retired Tek employee will see it.![]()
Dustin,
I'm not convinced any of the NI forums are appropriate. The only things you have mentioned are a Tek scope and a Tek program. How does National Instruments fit into this equation? Are you using an NI GPIB controller for the scope? If so, what is the model #? Any NI card that would have supported by this very old program would probably have been made obsolete by NI as well.
To repeat a previous suggestion, if you would explain exactly what you are trying to do, someone might be able to provide an alternative. However, unless you are going to purchase LabVIEW, one of the other language boards (CVI, VB, VC++, .NET) or the Instrument Control board would be more suited to follow up questions.
10-02-2007 10:10 PM
10-02-2007 10:27 PM
10-03-2007 01:21 AM
Grabber requires an IBM-PC XT/AT, or a fully compatible equivalent personal computer.
A wide
range of display adapters are supported, including CGA, EGA, VGA
and Hercules.
