Grablink Express - erreur - ChannelState ACTIVE
Bonjour a tous
J'ouvre un post sur le forum NI car je rencontre un problème d'initialisation de ma caméra Photonfocus MV-D1024-CL controlée via la carte Euresys Grablink Express.
J'ai installé le logiciel multicam et téléchargé les drivers sur le site NI. Ma carte est donc controlée via une dll (Multicam.dll).
Lorsque je lance Grablink Snapshot Y8 Sample.vi, j'ai une erreur qui apparait au niveau du sous-vi ChannelState.vi. Si je laisse la valeur ACTIVE, j'ai une erreur. Par contre si je la change en ORPHAN je n'ai plus d'erreur mais les acquisitions ne peuvent pas se faire...
Pouvez vous m'aider a résoudre ce problème?
Merci
A+
(4,044 Views)
Thanks to post on NI Forums, note that you're on the english part, the French one is located here:
http://forums.ni.com/t5/Discussions-au-sujet-de-NI/bd-p/4171
So, we'll continue in english. First I want to make sure that you have followed all the steps described in the specs part 2 : How to get started (CameraLink) :
User Manual MV-D1024 Series
http://www.photonfocus.com/upload/manuals/MAN001_e_V1_2_1024-series.pdf
Arrived at step 12, you should be able to grabb an image. If not you may check for certain compatibily issue, depending on you configuration :
Framegrabber compatibility
http://www.photonfocus.com/html/eng/support/framegrabbers.php
As stated in this page :
"Note that some framegrabbers use CameraLink™ chipsets limited to 66 MHz pixel clocks. These framegrabbers are not compatible with Photonfocus cameras from the -160 and -240 speed classes (cameras with an 80 MHz pixel clock, such as MV1-D1312-160-CL-12).
If you have compatibility questions concerning your framegrabber, please contact our support team via ."
Basically, you have to be able to get an image with the different tools the Manufacturer/FrameGrabber provide, that will ensure that all the drivers and hardware is working properly, before dinging in some LabVIEW wrapper driver issues. For all this installation I think that photonfocus can also support you.
Also, you have to know that if we can determine that the issue comes from the LabVIEW driver, I'll not be able to help a lot as I don't have any hadware and it is not supported.
Regards
Victor F. | Systems Engineer
Certified LabVIEW Developer | Certified TestStand Architect
National Instruments Budapest
(3,970 Views)
Dear Victor,
Thank you for your answer and I would like to excuse me for this French mistake. I can explain in English.
I installed drivers of my framegrabber and then I run Multicam software. Using this software, I can get acquisitions and the parameters seem to be correct (frame rate, exposure time...).
So I think I have not problems with drivers from camera and framegrabber and the compatibility is OK.
Thank you
Regards
(3,953 Views)
Is there someone who can help me? Smiley Sad
(3,936 Views)
Accepted by topic author eaglewatch86
The solution is : The pathfile of the dynamic library has to be C:\\Windows\system32\MultiCam.dll
See you
(3,866 Views)
