Gradient on the background of a slide bar
I would like to have a gradient [example: red to blue] on my slide bar background. I don't want it to change depending on the slider position, it should remain fixed.
However, I would like to be able to change it to another gradient [example: green to orange] at some point in the run time.
Can this be done?
Aleks.
(5,128 Views)
Yes, you can.
Here's an example I was given for a dial but the principle should be the same for a slide bar.
I've changed the colors around experimenting with it.
(5,121 Views)
Thanks!
But I forgot to mention, I have labview 7.1
Is there a way I could view your VI somehow?
Thanks again
Aleks.
(5,117 Views)
I'll post a screenshot of the code. That should help you reproduce it. Good luck!
Message Edited by Jarrod S. on 05-11-2006 12:54 PM
Jarrod S.
(5,109 Views)
I tried implementing your VI in labview 7.1. I can't seem to find the scale.interpcolor[] property in the property node. Is it possible that it's a LabView 8 exclusive property? If so, is there a LabView 7 equivalent?
Aleks.
(5,089 Views)
Hi Aleks,
a 'Meter' control has these properties (MarkerValues[], InterpColor), but a normal 'slide' doesn't have them!
So those properties are only available, when the scale already has a "colorful" background 🙂
But: you can put a second object behind your control to simulate the color ramp. Or you try your luck with customizing the control.
Message Edited by GerdW on 05-15-2006 01:34 PM
(5,080 Views)
