Graph Legend Text Font Size
I created a utility that plots multiple curves on an XY Graph and exports the image so it can be used for presentation.  Sometimes we have very long descriptors for the individual plots, and I have been trying to add a control for the text font size of plots in the legend in run-time.
I have added these controls for all other aspects of the graph (X & Y labels, scales, titles) but cannot find the property to control specifically the font size of the legend entries.
Is it true what I have been told by family members, and just don't look very hard for some things that are clear and obvious???
(2,514 Views)
A quick search and all I've found is others trying to do something similar, but there's no property node to do it.
https://forums.ni.com/t5/LabVIEW/Mixed-signal-graph-plot-legend-font-size/td-p/2313868
(2,498 Views)
Add this key to your LabVIEW.ini and restart LabVIEW:
AdvancedPlotLegendMenu=True
Then you can right-click your legend and create a reference / property node / invoke node to it:
If you create a reference, you will get an unnamed Array reference.
By inspecting its element, then the cluster elements, you can get the ref to the plot name string:
See this thread for more infos:
https://forums.ni.com/t5/LabVIEW/Graph-How-to-keep-quot-Legend-Number-of-Rows-Property-quot/m-p/4271...
Raphaël.
(2,464 Views)
Thank you very much!  This worked perfectly, but what a lot of work just to change a font size.  I am really surprised that this has not ever been addressed before.
(2,425 Views)
Usually you just select the text and change it through the font dialog. Having to change it as it's running is uncommon.
Qestit Systems
Certified-LabVIEW-Developer
(2,399 Views)
Agree, LabVIEW often has these kind of limitations when you try to do "too specific" things, especially for GUI customization.
As said by Yamaeda, doing it at edit-time is sufficient 99% of the time. If you really try to have a dynamic GUI that adapts to screen resolution, be ready to hit other limitations of this kind, because LabVIEW was really not designed to make responsive GUIs.
Generally, I'm happy that a solution exists at all, and actually not so complicated.
Don't forget to "Accept as solution" if a comment solves your problem and/or "Kudo" comment(s) that are helpful.
Raphaël.
(2,386 Views)
