Graph Palette shifts unproportionally when window is resized
@BertMcMahan wrote:
I cannot believe I never thought to try right-aligning the text.
Be very careful there! If you select the entire graph and select right-align, the axes (legend, markers, etc.) can get horribly corrupted later. (Just try it (on a new graph, not your own project!), looks fine initially, but then do a right-click...advanced...reset scale layout... Bam!!!)
While you can undo it immediately, you might reset the scale much later when undo of the font alignment is no longer possible. At this point, it cannot be fixed!
Message 11 of 13
(441 Views)
Ugh, that sucks. Thanks for the warning.
I like your demo but I'd add one thing- some little cosmetic separators. Something like:
Message 12 of 13
(430 Views)
Oh, one other fun one... if you have a horizontal legend of, say, 3 elements, then set Legend:Number of Rows to 1, then back to 3, it resets it to a vertical layout.
Message 13 of 13
(417 Views)
