Graph Problem
Hi all,
Please refer to the attached graph. How can I removed the line from 0 to -5. ? Any idea?
Please advice.
Cheyne
Message Edited by cheyne on 07-04-2008 05:02 AM
(3,277 Views)
Hi Cheyne,
it looks like an XY graph, so you should delete this point from the connected array.
Hope it helps.
Mike
(3,262 Views)
Specifically, it looks like both your X and Y arrays have a 0 as their first element. Is this data you read from a file, or something that was read from an instrument/DAQ, or something that you generated programmatically? If it's read from a file you may have a bug in your file-reading code.
(3,248 Views)
Hi all,
Thanks for the suggestion and reply. I have managed to solve the problem by removing the 1st row of my array which previuosly written with some strings.
Cheyne
(3,216 Views)
