Graph Scales
Hello Friends,
I am using Waveform Chart with multiple Y axis scales. Currently 6 Scales are used and made visible programatically. The Default No of scale is 6.
Now the question is, sometimes when I change the No of scales from minimum to maximum, the scales are overlapped on the plot area. Please see to the attachment.
How to solve this issue.
(3,164 Views)
@Vivek_Dev wrote:
Hello Friends,
You can resize the frame inside the graph chart control.
(3,130 Views)
Did you ever fine a solution to this problem?  I've been struggling with this for years.
(2,999 Views)
