Graph Scrolling and Zooming: Thanks Boalan and Bob B
Hello, a while back I found a great example of adding a scroll bar to a graph. The example was found in a post titled Graph Scolling and was submitted by Boalang (member) and was updated by Bob P (Proven Active Member). I want to say thanks to both members because from their work I was able to complete my application. My application reads a text file and graphs the data. I used Boalang's and Bob's method to add a slider that would scroll the data and it works great.
Thanks Guys,
joe
(2,758 Views)
Joe- You have been given stars for giving credit, and BTW, they updated your rank to to Proven Regular!wink smiley
(2,748 Views)
Not to nitpick (well, maybe just a little), the first sequence frame does not do anything. You should use the File Dialog if anything at all and not the Open/Create/Replace. The Read From Spreadsheet has this in there anyway and you could just enable the Browse button for the path control and eliminate the File Dialog as well. And can I ask why the built in scroll bar and zoom tools of the graph were not used?
(2,739 Views)
Dennis,
Hi, you are absolutely correct and am still learning new things everyday. I didn't know about the Browse button and I feel that is better approach.
thanks,
joe
(2,728 Views)
