Graph XY plot and click
Hi, i want to know how i can use the graph XY like this video? using the graph like input and output at same time
https://www.youtube.com/watch?v=aD_mB2W2nLo&t=111s
(3,523 Views)
That doesn't look like they are using the graph as an input. They have a numeric control for X and Y, and then display that on the plot.
(3,518 Views)
Look at cursors.
The target is a cursor (your control) and the current position of your device is a plot (indicator).
Here I simulate the real position of a device in the timeout case, simply get closer in 10 iterations, stop changing the position when it's reasonnably close.
(3,502 Views)
Thanks for the help, can you save the example in LabView 2017 this is my current version
(3,482 Views)
(3,451 Views)
