Graph XY - straight line 3 values
Hi All  -
I have an application where I have a value for my Y-axis, and I have a range in seconds on my x-axis.  All I want to do is draw a straight line, from 0 to 7 on my x-axis...at my value on Y-axis.  I've been looking at responses on the forum and it looks like I need an array of x/y values feeding into the plot.  Rather than populating tons of values....is there an easier way to just plot that one horizontal line at a value, and connect two points on my X axis?
(Note I have 3 of these that need to go on 1 plot)
LV7.1, LV8.5, LV2014/15/16
(3,229 Views)
On a XY Plot, LabVIEW connects all consecutive points with a straight line.  If you only have two values in your arrays, then the two points will automatically be connected with a straight line.  I'm attaching some sample code that shows you how to generate the straight lines as well as display them on the same graph.  Note that the method for including many graphs on one plot can be scaled to include more or fewer plots as necessary.
Kind Regards,
Justin Fuller
(3,218 Views)
10-4 Got it to work
Thanks a bunch
(3,210 Views)
