Graph :cursor error
Hello
I have a graph with two cursors in it. Those cursors help me to set an interval. After that I can calculate max., min. and mean values of the interval.
When I open a saved graph I often receive this error: error-1801 occured at start value toot large in Get Waveform Subset.VI.
I've tried many things but still no results.. I hope someone on the firum can solve the problem.
Tnx!
(3,385 Views)
Mind shaing the code.???
(3,377 Views)
I've put it as an printscreen in the word file
(3,359 Views)
Someone please?
(3,340 Views)
You might have better luck if you actually post a vi, not a picture embedded (somewhat unhelpfully) in a word file.
(3,335 Views)
