Graph data missing
G'Day Everyone,
I've got an app that plots data to a graph with the Y scale autoscaling turned off, and when I drag other windows over the front panel, the data doesn't get drawn (fair enough), but when I move the window away from the front panel, the data isn't drawn where the window was. I've attached an example of what I see, and a vi that exhibits this behaviour - has anyone a workaround for this one?
cheers,
Christopher
Copyright © 2004-2026 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(2,953 Views)
Christopher,
Is there something specific you do to make the data disappear? I ran the VI and then moved the diagram all over the place covering and uncovering the front panel and the data still seems to show up. Does it happen very repeatedly for you, or is it somewhat sporadic.
What is your video acceleration set to? Try slowing the acceleration down or even setting it to none and see if the issue continues.
(2,953 Views)
The fp and Diag have to be swaped on top of each other.
Thgis hapen on a number of computers. This is also only a simple example of the problem. I has to be run with auto scaling on Y turned off.
We have other projects that this is showing up on.
There can be point not drawn as well. Gaps in the data.
By draging an other window over the top of the graphs will then have the data points displayed again.
(2,953 Views)
