Graph from subVI to VI
Hello, I'm working on a school project and need some help with graphs in labview.
I am not a seasoned user so I dont know what excactly is happening.
When I try to link a graph with 12 sine functions from a subVI to one in my main VI the output is 12 straight lines. The lines are still reactive to input and change to zero when I switch a button that makes the input of the sine function 0.
I just think it's strange that the value of the graph in the subVI goes straight to the main one but changes it. I tried fixing it but nothing really worked. I just can't get my head around it.
Has anyone else ever had this problem? Any help would be appreciated.
(3,447 Views)
It'd help to see your two VIs, the caller and the subVI.
I suspect you're running into one of two issues:
1) You're only outputting a single value instead of an array from your subVI.
2) Your range on the main VI is small enough you're only seeing a small number of samples.
A graph requires you to feed it an array to give the entire data you want to graph.  If you only send it a couple of points, you won't see much.  If you only send it a single value, it'll be hard to make anything intelligible from the graph.  If you only want to feed a single value and have it maintain the history for you, take a look at charts instead.
Are you able to post the code so we can take a look and help you narrow down the issue?
(3,444 Views)
I'm going to assume you know the difference between a Graph and a Chart in LabVIEW, right?
A Graph is an indicator, meaning you load it with X-Y points and it shows them "on a graph".  If you have a Graph in your top-level VI and you load with points, it will show them.
If you have a sub-VI and put a Graph on its Front Panel (where you ordinarily would never see it), you can fill the sub-VI's Graph with points (12 sine waves) and it will plot them, but the Graph, itself, has no output back to the calling VI, so the calling Top-Level VI won't have any input and won't show any points.  Now, if your sub-VI output the 12 sine waves themselves, that you could plot on the top-level VI.
Bob Schor
(3,423 Views)
