Graph is not correct in another PC which have window 11 and microsoft version 365.
Hello Sir,
I have an issue in Ms office report. same exe I am running in my system which have window 11 and Microsoft office version 365 , report is Graph is coming correct, I have tested another PC which have Microsoft 2016 version and window 10 on this PC also report is coming correct. but in two PC with window 11 and Microsoft office version is 365 on those PC graph is not coming correct.
Please help me related this issue.
Message 1 of 16
(2,501 Views)
Can you define what "incorrect" means? (graph missing? distorted? wrong color? incomplete? wrong size? etc. etc.)
Message 2 of 16
(2,478 Views)
in one pc It is coming small size and in other Pc graph is coming oversize.
Message 3 of 16
(2,473 Views)
I am facing issue in Report generation in MS office 365 Window 11 in LabVIEW version 2020.
Same exe is running in other PC that have Window 10 and MS office 2016. I have checked window compatibility with LabVIEW that is given as shown in Below is image. issue is coming in graph in PC which have window 11 and Microsoft 365 Graph is coming in one pc it is too small in size and other PC with window 11 it is coming too Big. This is window compatibility issue or any other issue. Because we will use all PC with window 11, Microsoft 365.
Please help me on this issue.
Message 4 of 16
(2,432 Views)
LabVIEW 2020 is not compatible with Windows 11. It has not been tested and validated on Win11 hence the performance is not guaranteed. You should upgrade your LabVIEW to the compatible 2022 Q3 or later.
https://tmesystems.net/
Message 5 of 16
(2,375 Views)
Thanks for your response.
I have update LabVIEW 2022 Q3 and Build exe , still I am getting issue.
LabVIEW 2022 Q3 is compatible for MS office 365 or Not? and I am using LabVIEW 32 bit and Microsoft office Version is 64 Bit.
Due to Code interface node error I am using LabVIEW 32 Bit.
Message 6 of 16
(2,358 Views)
You are still missing to explain what is "coming too Big" for graph?
At least post some images of what you result should be and what it is.
Message 7 of 16
(2,345 Views)
Please find the attached report, Graph is coming as given in attached image.
On another PC with same exe Report is coming ok as given in below image.
Message 8 of 16
(2,339 Views)
That is clearly NOT the same report.
The table on top is not the same!
And if the data in the report is correct, then it is more an issue of MS Office than LabVIEW.
Is the template the same ?
Message 9 of 16
(2,328 Views)
Yes template is same and for same Data report is coming like below image.
Message 10 of 16
(2,324 Views)
