Graph palette special keybindings
Hi!
I have a graph which displays wave and some cursors. Is there a way to assign a special key binding for the graph palette controls? Say that I want to zoom in on the graph, then I could press the "z-button" on my keyboard and then the zoom in function on the palette would be selected. Same goes for pan, and cursor. Shouldn't there be a easy way in Labview to do this, or do I have to make a separated program?
Best regards Maurlind!
(3,518 Views)
I doubt you can do it directly. But you can create Event for key press and using that you can perform the Zoom operation in the Graph. Similarly you can perform the other operations.
(3,504 Views)
Hi maurlind,
If you think so you can add a new LabVIEW idea in the LabVIEW Idea Exchange!
You can control your graph with its property nodes. Use an event structure to determine key press events…
(3,490 Views)
Accepted by topic author maurlind
Solved it with keyevent and case structure, inside I paced a propertynode with Active palette tool
I used the basic code from this link:  http://digital.ni.com/public.nsf/allkb/D295B048D1B6E0D3862571EA005FBDE4
(3,469 Views)
