02-10-2023 01:51 PM
Hello everybody.
Recently we tried to bring back to life an old vapor compression cycle with a NI SCXI-1000 connected to LabView 10.0.1. In the front panel, there are 2 graphs, one with temperature and another with pressure. The one with pressure works okay, but the temperature one only shows variations of 1 ºC. I have tried to find when is set to display like that but I have not been able to find it. Below I attach a capture of the 2 cases, pressure as it should display and temperature with the problem. Also, I attach the LabVIEW file.
Thank you in advance.
02-10-2023 03:03 PM
In your lower graph, the data seems to be quantized to whole numbers. This could be because you use the wrong decimal delimiter (comma or period) when reading the data. Can you attach a datafile?
02-10-2023 03:22 PM - edited 02-10-2023 03:25 PM
OK, on a computer with LabVIEW now, looking at your code:
Oh boy! I think most her are not willing to untangle a gigantic diagram with mostly dynamic data and peppered with glaring Rube Goldberg constructs..
02-10-2023 03:33 PM
Maybe you could just wire a cluster of DBLs to define the type better. No idea if that would work. (Better programmers stay away from dynamic data!)
