Graph problem
Hi
How to make vi of the following formula
D=(e+t)/[1-(h-1)v]
d=delay,t=time,h=hops,v=utilization where  e is fixedand all other values are changes
I want to make Graph between Delay'D' and hops'h'
You can also checked my vi  which i tried but due to this there is no changes in graph
kindly help me iwill be very kind to you all thanks
(3,606 Views)
Instead of a regular graph, it sounds like you want to use the XY Graph to plot one array against another. You simply bundle the x and y arrays together and wire it the XY Graph.
(3,596 Views)
It seems you are linearly  ramping "h" from 1 to 10 with a constant increment. Just feed the D array to a waveform graph and set the x-axis offset to "1". That's it!
If the h values were not equally spaced, you would need an x-y graph. For equally spaced x, this is optional.
Both methods are shown in the attached (LabVIEW 7.0).
(3,583 Views)
how to make both vi  using xy graph
(3,531 Views)
Go to LabVIEW>> Find Examples>> Fundamentals>>Graphs and Charts>> XY Graph.vi
This example VI illustrates how to Build a X Y graph
(3,525 Views)
Have you even looked at my example above?
It shows the technique for both a waveform and an xy-graph. 🙂 Just deleted what you don't need.
(3,505 Views)
