Graph problem
Hi, can you help me?
Please can someone help me fix the scale of a graph when a cursor is dragged
to its edge? I want the cursor to be stopped when it reaches the edge of the
graph and for the scale not to change. I have done this programmatically
using case statements and property nodes but I wonder if there isn't a
simpler way of achieving the same using a property node,
James Annesley
(2,937 Views)
Hi James,
no problem,
you have to use property nodes.
The first Property is "Cursor PosX"
and the second is "YScale ScaleFit"
When cursor position 0 ( X scale) then YScale ScaleFit must be set 0
an other way YScale ScaleFit must be set 2
I'll end an example to you.
Best Regards
Mike Manzheliy
> Thanks
> James Annesley
(2,937 Views)
