Graph read value request
I've been searching for this idea for a long time.
At the moment I'm using a manufacture build .exe which was created in labview. I've downloaded the .llb file to edit the program for my purpose, yet I can't find a way to make it the way I want it.
Basically this program measures and puts the data into a graph, I want to know the value of a specific point in that graph. I want to go with my cursor to that point and see the value. But I can't find a way to do that in labview Smiley Sad
Is there a way to make it do what I want? Just make the cursor go to the specific point and then read the value? The graph can be found under 5015_measure with RS232.vi
In the attachments you will find the .llb and a picture of a point I want to read the value of.
Thank you!
(3,463 Views)
Accepted by topic author FailedEngineer
I am not totally sure if you already have a cursor and are looking for some way to better control it, or are looking to add a movable cursor to your graph, but if the second is your issue:
1. Right click the graph and go to visible items->Check cursor legend
2. Right click on the cursor legend and add a cursor of your choice.
(3,425 Views)
Thank you ngarneski!,
This was exactly what I wanted Smiley Happy
(3,358 Views)
